Addon installation help
webbcite
New WHMCS user and I'm trying to install the Enom New TLD addon. I've uploaded it to the modules/addons directory per the instructions. It doesn't show up under the "My Addons" section and when I search for Enom it shows as "Not Installed" with no activate or install button.
Since this is my first addon installation i'm wondering if I did something wrong. I thought it was just a matter of uploading the addon folder to the modules/addons directory.
Any help is appreciated
  • 5 months later...
