small "Slab" system bug
basic
Referring to the new pricing Slab system, there is a small bug -- I means this here:
http://docs.whmcs.com/Client_Groups
After creating a customer group and then special slab with different domain pricing for that group ... there are THREE action links on that created slab pricing list:
==> Activate Pricing Slab | Deactivate Pricing Slab | Reset to Base Slab Pricing
I did play with it and hit the "Deactivate Pricing Slab" .... but it did not just "deactivate, it actually *deleted* all the prices I had entered for that group. So it then seems that the "Deactivate ..." and the "Reset ..." link do in fact do the same. That can easily mean hours of work down the drain, if one does't know (as you only realize when you try to re-activate that slab again).
