quote for custom modification of the project management add-on - regarding tasks
We are looking at using whmcs for our billing and project management.
The project management add on does not cover some of the functionality that we would require and needs a few tweaks to perform as we would like.
One of the big things with the "project management add on" is that it allows you to add tasks, but it doesnt allow you to have sub tasks.
So say for the project below that we have the following TASKS AND SUB TASKS. Or probably a better way to say it would be STAGES and TASKS.
I would like to be able to add stages and then add the tasks to those stages, but the cms only allows me to just add a list of tasks.. So this project would be one big list of tasks.
Does that make sense?
I would like to modify it so that it allows me to include the stages and then be able to expand those stages to reveal the tasks that sit within.
I would be interested in a quote to develop this functionality.
Thanks for your time.
Regards,
Anthony.
Example of usual type of task list.
+ / - PREPARE ASSETS (STAGE - 1)
GATHER IMAGE FILES AND PUT IN FOLDERS (TASK 1)
SETUP TWITTER BOOTSTRAP FRAMEWORK AS BASE TEMPLATE (TASK 2)
SIZE IMAGES TO SUIT (TASK 3)
GATHER FONT FILES (TASK 4)
SETUP LOCAL DEVELOPMENT ENVIRONMENT (TASK 5)
+ / - WORDPRESS TEMPLATE CODING (STAGE -2)
HOMEPAGE CODING (TASK 1)
PAGE TEMPLATE CODING (TASK 2)
POST TEMPLATE CODING (TASK 3)
CATEGORY TEMPLATE CODING (TASK 4)
ARCHIVE TEMPLATE CODING (TASK 5)
ROTATING BANNER/SLIDER (TASK 6)
MAKE BANNER IMAGES RESPONSIVE (TASK 7)
CONTACT PAGE GRAVITY FORM SETUP & INTEGRATION (TASK 8)
PAGE LAYOUT SELECTION
+ / - DEPLOYMENT SETUP (STAGE -3)
UPLOAD TO SERVER (TASK 1)
DATABASE ACCOUNT SETUP (TASK 2)
etc....
