VanFenix Posted January 25, 2013 Share Posted January 25, 2013 Looking for a Developer to give me a hand. I have WHMCS 4.5.2 Everything was smooth, but WHM ran some updates, and now my hooks are not working. I have WHM 11.34.1 (Build 7) with Cpanel - fully up to date. In WHMCS -with a Client Profile Loaded -- under Products / Services I have "Module Commands" When I click CREATE - It should run my kits. It creates the account in WHM It creates a cpanel account It creates a database within the account which should be populated with the website tables and fields But it does not Decompress the ZIP file containing a default website (which should be installed via "create" module) It does not Decompress the sql.gz file either. It copies the compressed files into their public_html folder but then it stops there. I am not sure why it won't decompress and I'm not the best at this stuff (Dyslexia is harsh). It could be something with httpd.conf But I would not know where to start. I've tried my old kit files - and it does the same thing. sets up the username - creates a public_html - drops the packages in there - and stops. Any help is appreciated. Thanks! Van 0 Quote Link to comment Share on other sites More sharing options...
