Help with product details when using hooks
chateaux
I am writing a hook to update an external AP which is called on the ShoppingCartCheckoutCompletePage, the following $vars relate to the product purchased are made available to me via the $vars variable:
   [orderid] => 33
   [ordernumber] => 4527979924
   [invoiceid] => 33
I need to find specific details relating to the product purchased so I can update my external app accordingly and am sure their is a simple way to do this. I just cant find the information in the documentation.
Can anyone advise?
Many thanks!
Array
   [carttpl] => verticalsteps
   [currency] => Array
           [id] => 1
           [c ode] => USD
           [prefix] => $
           [suffix] =>  USD
           [format] => 1
           [rate] => 1.00000
   [ipaddress] => 55.555.55.55
   [ajax] =>
   [numitemsincart] => 0
   [orderid] => 33
   [invoiceid] => 33
   [ispaid] => 1
   [amount] => 0.01
   [paymentmethod] => paypal
   [clientdetails] => Array
           [userid] => 5
           [id] => 5
           [firstname] => Firstname
           [lastname] => Lastname
           [companyname] =>
           [email] => myemail@myisp.com
           [address1] => my address
           [address2] =>
           [city] => my city
           [state] => my state
           [postcode] => 0070
           [countrycode] => ZZ
           [country] => ZZ
           [countryname] => Country Name
           [phonecc] => 00
           [phonenumber] => 000000000
           [notes] =>
           [password] => 13e535b50a1ced7a629d386ee6291678:l%G)o
           [currency] => 1
           [defaultgateway] =>
           [cctype] =>
           [cclastfour] =>
           [securityqid] => 0
           [securityqans] =>
           [groupid] => 0
           [status] => Active
           [credit] => 0.00
           [taxexempt] =>
           [latefeeoveride] =>
           [overideduenotices] =>
           [separateinvoices] =>
           [disableautocc] =>
           [language] =>
           [lastlogin] => Date: 24/01/2013 10:48<br>IP Address: 55.555.555.555<br>Host: hostname
           [billingcid] => 0
Reviewing the API functionality I see I can use:
http://docs.whmcs.com/API:Get_Products
However the only commands available to me via the internal API are:
$command = "getproducts";
$adminuser = "admin";
$values["gid"] = 5; //OR PID, GID, MODULE
$results = localAPI($command,$values,$adminuser);
None of which has been made available on the checkout complete page via the $vars...
It would seem the other option would be to use:
http://docs.whmcs.com/API:Get_Orders
Using any of these:
[orderid] => 33
[invoiceid] => 33
$command = "getorders";
$values["id"] = $vars['orderid'];
I get an empty array as a result...
Anyone know what to do? I just need to know what the client has ordered... should be simple, just cant work it out.
Ahh ok - that would explain why I cant find an API function to grab the product details.
One more question, is there a way to pass a variable to WHMCS when a client places an order? I need this to divert the customer back to the app... or should I just add a variable to the users session?
Opting to simply pull the information our of the database... but am stumped as to how to link back to products, this is what I have to work with:
Invoice ID
Order Number
Order ID
The object is to get the ID's from the order placed and find out which products where purchased and so I am looking at the following tables:
1. tbproducts - this is where my products that I created live and my ultimate destination
2. tblorders - I have the orderID for this table and OrderNum for this table, however there are no references to the tblproducts database
3. tblinvoices - I have the InvoiceID, however their are no further references to any other table
4. tblinvoiceitems - I have the InvoiceID for this table AND the product description here BUT no ID. I could match the product description in this table to the product description in tblproducts, however this is something I am not prepared to accept as a solution... I do note a 'relid' however I am unsure what table this relates to?
Ahh, okay I have worked it out... in table tblinvoiceitems, the products I have created are listed as type: "hosting", so when I look in the tbl hosting table, I find the products that have been purchased. I guess the naming convention is due to the WHMCS having stemmed from a hosting background.
So this is my process, hope it helps others:
Create hook for: ShoppingCartCheckoutCompletePage
1. The ID from the $vars I require is: OrderID
2. Use OrderID in table tblhosting to grab the information I need
Voila,
Thanks!
