Offline Credit Card Processing Issue
thehoster
Dear Community,
I am having issue, I have been testing this gateway for use for my customers. However when i put the CC key into the admin panel to display the card details and all i get in the following;
Card Type:
Card Number:
Expiry Date: (MMYY)
It didnt actually display the card details it came up as it is above in the popup window? any ideas on what this may be?
Regards
The fields come up for the customer to fill in and so they also do in the admin panel. Its just when i put the secret key in to display the credit card data so i can input the card details into my CC terminal manually it just displays the card details in the processing window as i put in the OP. It may also be worth noting that i have also tried to use one of the default templates to see if it was any of my code interuptin the process and it had the same results (no card details showing in the administration cp) hope someone can help me.
Edited by thehoster
