[Help] Multiple Products Under 1 Group -- Making them each have different Cart ID's?
gsteelx
I am very new to WHMCS... I have tried searching, but I can't really think of the name of something that I am trying to do. I will try to give you an example:
I will sell 3 services, voice servers.
Under each different type of Voice Server, I will have mutiple packages.
So as an example:
Ventrilo
10 Slot
20 Slot
30 Slot
etc...
Is there anyway to get a CART ID (or a link) that my users will be able to click on from my HTML page, that will take them DIRECTLY to the package that they have selected? From examples I've seen, most people using WHMCS give the same links to all their packages, then the customer just goes to the cart, and re-selects what package they want... This seems like a hassle and a waste of time for customers to have to do.
I guess a better example would be
Ventrilo
10 Slot so this would go to /whmcs/productID10slot (or whatever just making something up)
20 Slot so this would go to /whmcs/productID20slot
30 Slot so this would go to /whmcs/productID30slot
etc...
In stead of having what I have now :
20 Slot so this would go to /whmcs/productID1
30 Slot so this would go to /whmcs/productID1
in which it would take them all to the same page adn then they have to re-select what they want in order to check out
I believe HostBill has this feature, but I am looking to see if WHMCS does as well...
If anyone knows what I am talking about, or can point me in the right direction, it would be so much appreciated.
Like I said, I tried to search, but I couldn't find anything mainly due to the fact that I don't know what this would be called...
Sorry if I am confusing anyone. Long time Micro Niche Site builder, first time using WHMCS. Have re-sold other things in the past but never this. So any help would be greatly appreciated!
Thanks so much!
