WHMCS layout problem in IE 9
iskill
HI,
When we make order under the order summary , it display properly in the chrome browser but when we using IE9 it run out of range (not in proper view). We checked using F12 and it caused by the customize payment gateway module which requested javascript code place in the module, it mean javascript code before the html tag but since we can't put the code between the <head> tag because all the php code is encrypted by ioncube. any suggestion what can we do ?
thanks
