vb2cans Posted October 1, 2012 Share Posted October 1, 2012 Hi I need some help on coding. The below code displays this when adding items to cart. (The reason there is $48.50 + $11.45 is that the $48.50 is a recurring sale and I have added a setup fee to make up the difference for the one time purchase to make the total price $59.95) Billing Cycle 1 Year Number of computers: 1 $48.50 + $11.45 I would lie to change it to calculate the $48.50 + $11.45 And just display 1 $59.95 Code: {if $configurableoptions} {*<p class="cartsubheading">{$LANG.orderconfigpackage}</p> <p>{$LANG.cartconfigoptionsdesc}</p>*} <div class="cartbox"> <table cellspacing="0" cellpadding="0"> {foreach key=num item=configoption from=$configurableoptions } <tr><td class="fieldlabel">{$configoption.optionname}:</td><td> {if $configoption.optiontype eq 1} <select name="configoption[{$configoption.id}]"> {foreach key=num2 item=options from=$configoption.options} <option value="{$options.id}"{if $configoption.selectedvalue eq $options.id} selected="selected"{/if}>{$options.name}</option> {/foreach} </select> {elseif $configoption.optiontype eq 2} {foreach key=num2 item=options from=$configoption.options} <label><input type="radio" name="configoption[{$configoption.id}]" value="{$options.id}"{if $configoption.selectedvalue eq $options.id} checked="checked"{/i {/foreach} {elseif $configoption.optiontype eq 3} <label><input type="checkbox" name="configoption[{$configoption.id}]" value="1"{if $configoption.selectedqty} checked{/if}> {$configoption.options.0.name}</ {elseif $configoption.optiontype eq 4} <input type="text" name="configoption[{$configoption.id}]" value="{$configoption.selectedqty}" size="5"> x {$configoption.options.0.name} {/if} 0 Quote Link to comment Share on other sites More sharing options...
