Upgraded to 5.1.2 and admin/configregistrars.php is not working, help!
s33
Upgraded from v 4.x to v5.1.2 per upgrade doc. Cleaned cache. Registrars configuration does not work for me now - page shows registrar logos with 3 buttons(1st attachment) which do not do anything if clicked.
Re-upgraded /admin with files from 5.1.2 zip again - same thing. Checked WHMCS demo server, admin/configregistrars.php looks totally different (2nd attachment). Can't do domain registration now because of domain reseller is not working, help!
Enabled logging, got this from admin/configregistrars.php:
Fatal error: main() [function.require]: Failed opening required 'YourSRS.php' (include_path='.:/usr/lib/php:/usr/local/lib/php:/xxx/public_html/clients/modules/registrars/onetworegister') in /xxx/public_html/clients/modules/registrars/onetworegister/onetworegister.php on line 0
And there is no onetworegister registrars directory in 5.1.2 archive either.
Edited by s33
  • 1 month later...
Cheers for that s33 - saved me a world of pain... Had the same issue, found your post, sorted in a few seconds.
I had 3 registrars in the public_html/whmcs/modules/registrars that were left over from years gone by.
For anyone else who has the same issue:
  • sort the public_html/whmcs/modules/registrars folder by date (oldest->newest).
  • Select any folders which are much older than the recent install. (I had 3 registrar modules from 2009 !!)
  • Archive them and download archive.
  • Delete those folders (the old ones).
  • Reload your configregistrars.php page and all should be working well.
(If not, you have a backup of any folders you removed, install one at a time, but the above should fix your issues)
Once again, thanks s33
