ae6dx Posted July 9, 2012 Share Posted July 9, 2012 Since upgrading to 5.1.2 I'm not getting the WHMCS email database back up nor am I seeing the email from WHMCS saying the cron job ran. I upgraded following the instructions so no file paths have changed. I did not change anything in cpanel cron settings either. How do i fix this? 0 Quote Link to comment Share on other sites More sharing options...
nicklfire Posted July 26, 2012 Share Posted July 26, 2012 I seem to have the same issue after upgrading 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 26, 2012 Share Posted July 26, 2012 the path of the crons has changed, they now have their own cron folder.... also crons have new names.... look in thecron folder and change the path in the cron job accordingly... all should work then 0 Quote Link to comment Share on other sites More sharing options...
nicklfire Posted July 26, 2012 Share Posted July 26, 2012 the path of the crons has changed, they now have their own cron folder.... also crons have new names.... look in thecron folder and change the path in the cron job accordingly... all should work then I realize this for the domain sync but for the other cron job which was php -q /home/hosting/public_html/whmcs/admin/cron.php That has changed? 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 26, 2012 Share Posted July 26, 2012 the admin cron is still in the same place for us as it was originally ... have you tried running it manually too? any error? 0 Quote Link to comment Share on other sites More sharing options...
nicklfire Posted July 26, 2012 Share Posted July 26, 2012 I just deleted the cron job and i setup a new one, i ran it manually and it worked, guess i'll just wait and see if it runs at midnight 0 Quote Link to comment Share on other sites More sharing options...
lance Posted July 26, 2012 Share Posted July 26, 2012 hope its sorted and starts working for you. 0 Quote Link to comment Share on other sites More sharing options...
nicklfire Posted July 26, 2012 Share Posted July 26, 2012 yea, but it makes me wonder why it stopped after doing the upgrade it's not like the path was different or anything. I dont see why it worked when i manually ran it vs.. the automated way.. just seems odd, guess we will see. i'll update the thread in 24 hours if it has run. 0 Quote Link to comment Share on other sites More sharing options...
