mojohost Posted June 24, 2012 Share Posted June 24, 2012 Simple "bug", but very frustrating. Using the eNom registrar, I select the "DefaultNameservers" option, which states: Tick this box to use the default Enom nameservers for new domain registrations. In theory, this sounds very simple and exactly like what I need, however, it sets this in eNom: This should not be "Custom" populated with eNom's nameservers. It should be "Our Servers". eNom treats these very differently. If you choose "Custom" and use their nameservers it does not enable many of their services or utilize my default host record values I have set up in my eNom account. Checking "DefaultNameservers" should select "Our Servers" in eNom: I have seen this posted on here somewhere before, but after searching I could not find any threads directly related to this so I'm posting as a new issue. 0 Quote Link to comment Share on other sites More sharing options...
mojohost Posted July 17, 2012 Author Share Posted July 17, 2012 No replies, really? 0 Quote Link to comment Share on other sites More sharing options...
