TommyK Posted May 30, 2012 Share Posted May 30, 2012 Getting no error message or anything, but the info does not save. Anyone see why? $command = 'updateclientproduct'; $values = array('serviceid' => $params["serviceid"], 'customfields' => base64_encode(serialize(array('Fieldname' => "data")))); $adminuser = 'adminusername'; # Call API $results = localAPI($command,$values,$adminuser); if ($results['result']!="success") echo "An Error Occurred: ".$results['result']; return $results['result']; /Tommy 0 Quote Link to comment Share on other sites More sharing options...
TommyK Posted May 30, 2012 Author Share Posted May 30, 2012 I found out my problem. The code in OP is not working. A working example is below; $command = 'updateclientproduct'; $values = array('serviceid' => $params["serviceid"], 'customfields' => base64_encode(serialize(array("3" => "data")))); $adminuser = 'adminusername'; # Call API $results = localAPI($command,$values,$adminuser); if ($results['result']!="success") echo "An Error Occurred: ".$results['result']; return $results['result']; The id of the array values wasn't from 0 to 4 in my case, they were scattered little bit. So I also had to enter Display Order for all of my custom fields on my product. 0 Quote Link to comment Share on other sites More sharing options...
