jasonmccurry Posted March 25, 2012 Share Posted March 25, 2012 How am I able to disable the affiliate system for clients? I have done this before and have looked in the docs, this is getting on my nerves. 0 Quote Link to comment Share on other sites More sharing options...
tripler Posted March 25, 2012 Share Posted March 25, 2012 Remove any reference to affiliates in your template files. 0 Quote Link to comment Share on other sites More sharing options...
jasonmccurry Posted March 26, 2012 Author Share Posted March 26, 2012 I would like to offer it to non-clients as well, not just do the lazy way and removing it. 0 Quote Link to comment Share on other sites More sharing options...
tripler Posted March 26, 2012 Share Posted March 26, 2012 (edited) You would like to offer what to non clients? The ability to be an affiliate (which would then make them a client) or to not offer affiliate program to non existing clients? I did not suggest a "lazy way" If you want to remove the ability to have an affiliate program then you need to remove the references to the affiliate logic within your template. edit* Comment it our instead of deleting so you dont regret it later. Edited March 26, 2012 by tripler 0 Quote Link to comment Share on other sites More sharing options...
