Not a helper Posted March 24, 2012 Share Posted March 24, 2012 How do I add small feature boxes as in red marked area. Thanks for help! 0 Quote Link to comment Share on other sites More sharing options...
DavidBee Posted March 24, 2012 Share Posted March 24, 2012 Hey, Check this out Feature Highlights are supported by the Slider, Modern and Comparison cart templates. The idea behind these is to allow you to highlight or bring attention to certain key features of each product/service.They are used by entering features in the format "Attribute: Value" within the product description field, one per line, starting on the first line of the description. And in the case of the Slider & Modern templates, you can also include a text description to be displayed below them. http://docs.whmcs.com/Standard_Order_Form_Templates#Using_Feature_Highlights 0 Quote Link to comment Share on other sites More sharing options...
