DirectI Registrar Module - hard work for Brazil
brasiweb
Hi, Matt!
Here on Brazil we have the telephone number commonly inserted in a strange way, compared to EUA, with area code inside parenthesis, and a hiphen in middle number:
(XX) YYYY-ZZZZ
I'm having some trouble with DirectI, since they don't allow ANY alpha characters: I have to edit all customers telephone numbers frequently, to avoid interruptions in domain register automation through DirectI, and sometimes customers re-edit their phone numbers...
May you do some arrangements in DirectI module functions to read the telephone field removing the spaces, parenthesis and hiphens when registering a domain? XXYYYYZZZZ are 10 characters, the max allowed by DirectI (excluding the Country Code).
And, maybe, add a Country Code field also, with a pre-inserted code when registering (since a lot people here doesnt even know the existence of a code for each Country)?
Thanks in advance.
you can create a function on the telephone input boxes to call a function... ie:
<input name="phonenumber" size="20" value="" type="text" onchange="javascript:translatenumbers(this.value,'telno');" id="telno">
then write your function... something like:
function translatenumbers(str,myid){
str = str.replace(/(A|B|C)/ig, "2");
//...do the rest here ... etc ...
//...then pass it back to the input box...
document.getElementById(myid).value = str;
Thanks, trine. But i'm a leading zero in JS...
I will ask some friends if they could do it for me.
Again, Thanks!!
And thanks for the info I can move services through DirectI accounts, also, if you didnt read there topic again! :)
brasiweb, try the following.
Modify the phonenumber input to read:
Insert your
<script language="javascript" type="text/javascript">
// replace all A-Z characters in phone field:
// (this is a case insensitive replace)
str = str.replace(/(D|E|F)/ig, "3");
str = str.replace(/(G|H|I)/ig, "4");
str = str.replace(/(J|K|L)/ig, "5");
str = str.replace(/(M|N|O)/ig, "6");
str = str.replace(/(P|Q|R|S)/ig, "7");
str = str.replace(/(T|U|V)/ig, "8");
str = str.replace(/(W|X|Y|Z)/ig, "9");
</script>
Hum... Now i understand it.
But i think you don't understand what i need.
I just need the spaces are removed, not translate it from letter to numbers. I use XXYYYYZZZZ just to show the format i need it.
Ex:
(11) 5543-9876
+55 11 5543-9876
(011)55439876
etc...
shoud all be turned on:
551155439876
Got it now?
remove spaces, hiphens, paranthesis and plus characters, and initial zero if have... and check if it have 55 at start. If dont, automatically add it.
Thanks if someone can help.
