klamort Posted February 25, 2012 Share Posted February 25, 2012 Hi, I had to reinstall WHMCS, and I am running into a small problem. Once the paiement has been received, it does not create automatically in directadmin the account... and when I want to create it manually, I receive this message: Module Create Failed - Service ID: 98 - Error: 56 - Recv failure: Connection reset by peer Any help is appreciated... Thanks 0 Quote Link to comment Share on other sites More sharing options...
gbrennae Posted February 26, 2012 Share Posted February 26, 2012 Are you running WHMCS and DA on the same system? ie are you making a localhost request from WHMCS to DA? 0 Quote Link to comment Share on other sites More sharing options...
klamort Posted February 27, 2012 Author Share Posted February 27, 2012 Are you running WHMCS and DA on the same system? ie are you making a localhost request from WHMCS to DA? Hi thanks for your reply, And yes everything is running on the same system... But I mus have forgoten something when I did reinstall the whole system... everything was running fine before. 0 Quote Link to comment Share on other sites More sharing options...
ramsy Posted February 27, 2012 Share Posted February 27, 2012 Try enabling or disabling SSL and check that you are using the right credentials ie. password in your server setup. 0 Quote Link to comment Share on other sites More sharing options...
klamort Posted March 2, 2012 Author Share Posted March 2, 2012 I checked, and everything seems to be ok... with ssl activated i get: Module Command Error 35 - error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol but nothing is working. Thanks anyway. 0 Quote Link to comment Share on other sites More sharing options...
i-hotspots Posted March 13, 2012 Share Posted March 13, 2012 Hello, I installed WHMCS just 4 days ago, WHMCS is on DA installed, and I have the same problem, NO PLANS created !? ANY IDEAS OR HELP Thanks a lot Andy ;P 0 Quote Link to comment Share on other sites More sharing options...
namesonic Posted March 13, 2012 Share Posted March 13, 2012 I installed WHMCS and connected to a Plesk10 panel. When I use the module commands like "create", "terminate", etc, the webpage goes "The connection was reset". However, the panel user and subscription were created/terminated successfully! The username and password are correct but the webpage does not return after submitting the module command. I think this is a similar problem. 0 Quote Link to comment Share on other sites More sharing options...
