alanp Posted January 30, 2012 Share Posted January 30, 2012 Hello, I am trying to install the futurepay gateway. In the documentation (http://docs.whmcs.com/WorldPay) it says that you need to set up a daily cron job for the futurepay charges: php -q /home/username/public_html/whmcs/modules/gateways/callback/worldpayfuturepaycharges.php But I don’t appear to have this script on my installation. Has this changed? Many thanks Alan 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted January 30, 2012 Share Posted January 30, 2012 It looks like the file is called "worldpayfuturepay.php" However, it doesn't make sense that you would be putting a callback script in your crontab. You might want to check with support on that. 0 Quote Link to comment Share on other sites More sharing options...
alanp Posted January 31, 2012 Author Share Posted January 31, 2012 Thank you Frank. I have requested this information from WHMCS support but I have not yet had an answer. Is anybody else using the futurepay gateway? Many thanks Alan 0 Quote Link to comment Share on other sites More sharing options...
