Nominet module "locality" field does not work
Terra
With the Nominet module, under "modify contact details" the "locality" filed does not work. Text can be entered, but it is not transferred to Nominet.
Tested with WHMCS 4.5.2 in WHMCS admin area & client area (bug affects both)
Looking at the EPP documentation from Nominet, there is no 2nd address line:
URL: http://www.nominet.org.uk/registrars/systems/standardepp/amendaccount/
<contact:addr>
<contact:street>High Street</contact:street>
<contact:city>Oxford</contact:city>
<contact:pc>OX1 1AH</contact:pc>
<contact:cc>GB</contact:cc>
</contact:addr>
If you can remove the "locality" line then this would greatly reduce confusion. I don't see any other changes being needed, just for this one line to be removed from the Nominet "amend contact details" screen in both admin & client area.
Many thanks,
Edith
