problem with order flow
nobody
Right now i have products setup corectly in WHMCS, they work fine. they setup as normal in cpanel.
My problem is, when i give a promo code that provides the first month free (eg. 0.00 first invoice/100% off one time(monthly)) it will bypass the fraud check - meaning:
when an order that should be marked as fraud is placed, and the promo code that gives the first month free this goes on:
order is placed -> order is setup -> fraud check fails -> order and product are updated to fraud
however: the product is still setup and the welcome email is sent out.
Has anyone else had this problem?
I use maxmind by the way.
EDIT: as a sidenote: when the promo code isn't used: the fraudcheck system works as it should.
