shotgun Posted November 1, 2011 Share Posted November 1, 2011 Hi All, We have a problem with one of our whmcs installations. After a recent upgrade we are getting the system offline for maintenance message when the cron.php script is run from crontab. eg : php -q /var/www/clients/admin/cron.php <div style="border: 1px dashed #cc0000;font-family:Tahoma;background-color:#FBEEEB;width:100%;padding:10px;color:#cc0000;"><strong>Down for Maintenance</strong><br>An upgrade is currently in progress... Please come back soon...</div> I'm not quite sure why this would be the case as the admin and client area's are ok when accessed through a browser. As this happened suring the upgrade I'm concerned that something else could be broken. I have asked support but they are not really helping. I know I can use GET instead (support suggestion) but that doesn't fix the issue. It just gets me of their back, which is annoying. Anyhow, I'm guessing there could be a lock file or db flag somewhere - so if you know where to look please let me know and I'll try to get it fixed. Many Thanks. -A 0 Quote Link to comment Share on other sites More sharing options...
cpoalmighty Posted November 1, 2011 Share Posted November 1, 2011 There is no way to tell for sure unless we took a look at the cron running and the database files. Could be a number of issues. 0 Quote Link to comment Share on other sites More sharing options...
