don_will Posted June 21, 2007 Share Posted June 21, 2007 hello, i think this is the right section. ive read support.whmcs.com/knowledgebase.php?action=displayarticle&catid=4&id=38 but when ive choose "Option 7" got errors "Sorry, a previous config file does not exist! Using Defaults!" And after that apache config option is come: " Apache Configuration 1.5.402 (for cpanel <= 10.9.3) (ap=1.3.37)" But i didnt see curl option. and there's no curl file or folder in usr/bin/ please help me. 0 Quote Link to comment Share on other sites More sharing options...
Adam Posted June 21, 2007 Share Posted June 21, 2007 Hey, Looks like you never ran easyapache before or never saved the config file. You will need to run easyapache using either option 6 or another option. You can also contact me and I can do this for a small fee. Thanks, Adam 0 Quote Link to comment Share on other sites More sharing options...
don_will Posted June 21, 2007 Author Share Posted June 21, 2007 yes never run before. choosing option 6 still problem.. 0 Quote Link to comment Share on other sites More sharing options...
Adam Posted June 21, 2007 Share Posted June 21, 2007 yes never run before. choosing option 6 still problem.. Hey, Are you choosing the option of cURL and cURL SSL? If you are still having trouble, get a hold of me, (using the buttons below) and I can recompile Apache/PHP with this option and much more for a small fee. From, Adam 0 Quote Link to comment Share on other sites More sharing options...
don_will Posted June 21, 2007 Author Share Posted June 21, 2007 There's no options for Curl and curl SSL. 0 Quote Link to comment Share on other sites More sharing options...
Adam Posted June 21, 2007 Share Posted June 21, 2007 There's no options for Curl and curl SSL. Hey, Yes their is, make sure you have read the article in full. Choosing any wrong option may break your Apache web server. I recommend you hire someone to do this for you, (like my self) or a server management company so recompile Apache/PHP for you. From, Adam 0 Quote Link to comment Share on other sites More sharing options...
don_will Posted June 21, 2007 Author Share Posted June 21, 2007 Finally Fixed... thanks nyway Adam for your replying.. but i dont know ho wto run this 0 9 * * * php -q /home/fartuah/public_html/order/whmcs/admin/cron.php what is the * mark.. 0 Quote Link to comment Share on other sites More sharing options...
Adam Posted June 21, 2007 Share Posted June 21, 2007 Hey, Thats for your cronjobs. Login to cPanel and find the cronjobs section. Chose advanced and type that in. OR In ssh type crontab -e and copy the whole thing 0 9 * * * php -q /home/fartuah/public_html/order/whmcs/admin/cron.php Close and Save. From, Adam 0 Quote Link to comment Share on other sites More sharing options...
