WHMCS Provisioning problems
evanion
Hey
We can't seem to get Interworx and WHMCS to play together.
When we try to provision a new user via the WHMCS system, we get an error 500.
general info:
WHMCS is hosted on the same server.
API key is added in the server info in WHMCS
Superadmin (Master) is added to the server info.
Server info in WHMCS:
hostname: snowpeak.se
IP: the external IP for the server
Nameservers: 2 nameserver urls to the same server (directs back to the same server)
Type: Set to interworx
User info: Interworx master admin
API key without start and end tags.
Secure is set to not use SSL Mode as we don't have a real certificate yet (got selfsigned - not activated for the snowpeak vhost).
This is our most critical problem right now.
Any help would be apreciated, as I have been sitting with this for a week now!
Best Regards
Mikael Pettersson
Snowpeak Hosting
Turns out that SOAP was missing.
php-soap doesn't get installed with regular php install (centos 5.x), I would recommend that you add that info to the Interworx intergration documentation, in order to help my fellow interworx users. :)
