wwwcad Posted June 9, 2011 Share Posted June 9, 2011 If you add a TXT record with the value test when the page is reloaded the data is not there because is not sanitized or it should be pass through html_special_chars, the HTML code of the resulting input is here: <input type="text" name="dnsrecordaddress[]" value=""'test'"" size="40" /> Like you can see, ResellerClub add two additional quotes but whmcs is not sanitizing them. Regards 0 Quote Link to comment Share on other sites More sharing options...
