need help please
smileys
I have editted templates before with other systems, know html well but not php too good.
I am now building my site, but am not sure how to intergrate into whmcs. I've done some searches and read a lot, but it all refers to going to templates/header.tpl or footer.tpl inside my templates folder I don't see these the header and footer.tpls I see are for the client area?
I am using v3.1.2
So I'd like to know if there is an easy way to intergrate my site to whmcs?
Are there any stepbystep manuals or anything to follow on how to do this?
Thanks
Laura
Under the templates/default folder will be a list of .tpl files. These are basically html files that you can edit. Also under this folder are css files. It really is as simple as that. You don't need to be editing any php (you can't as it is encoded) you just need to be careful with the smarty tags in the template files.
