[NOT A BUG] Need help with Coupon
Hi i created a coupon in my WHMCS now when i goto test it in the order page and use the coupon code and vaildate i get this error
The promotion code you entered has been applied to your cart but no items qualify for the discount yet - please check the promotion terms
can anyone help me out i really dont know what im doing wrong i followed WHMCS Tutorials
thanks
You should tell us how you have configured your coupon and then tell us what you are trying to buy with your coupon. This way, we'll be able to tell you what's wrong.
Exemple: You have set 10% OFF of domain name only if bought with hosting plan.
Then, you try to apply the coupon code on domain names without hosting plan!
i followed this tutorial
i set the coupon code for %10 for hosting plan when applied again this is error
Sounds like you have either applied it to a different product or you have set a requirement.
As astralinterne says, tell us how you have configured it (a screenshot would be good) and tell us which product you are trying to order that gives you the error.
