Need Registrar Module for NIC.RU
I need someone to create a fully working registrar module for NIC.ru registrar, especially for .RU/.SU/.РФ.
The module should have functionalities of:
- Creating a new customer profile first - which is how the NIC.RU works
- Registering a domain for the customer
- Updating/modifying customer and domain details (Contact info, DNS)
- Renewing domains OR canceling renewals
Please contact me at info {@} alfalogic.com if you think you can do this quick and with quality. I will only pay 30% upfront and the rest ONLY when the module is tested to be 100% operational and bug-free.
I will provide all documentation and whatever will be needed to create the module.
Check out this http://whmcs.com.ua/ there have modules ready and you can just buy some of them. But for good registrar I say is the reg.ru with very good services .
Hi and thanks for suggestions. I'm well aware about alternative registrars and their services and prices.
But I still need NIC.RU module. I have it working only in Russian and it's not FULLY operational, so need someone to write from zero a working and tested one.
Please contact me if you can do it.
I would sugest contacting info@hexonet.net
http://www.hexonet.net/epp1.php
this will give you all the info you need if you are a registrar for a domain, we are .it registrars and use hexonets epp 1.0 service and it has been amazing for us. there api is already supported by WHMCS and as such all is possible.
if not then they also do .ru registrations and again all is possible
  • 2 years later...
Language: English
Module should have the following functions:
- Updating/modifying DNS
Note: I do not want new profiles to be created each time or new account to be created each time on nic.ru/en
Instead i would like each domain to be registered under the main nic.ru/en account (my account).
PM me here with your contacts.
MSN, SKYPE ICQ and JABBER.
Thanks
