marie2007 Posted May 11, 2007 Share Posted May 11, 2007 Hi All I have just signed up for the 15 day free trial, however I can't find where to download it, is it under support as that is the only place I can see a dowload link. Also can any one advise with regards to installation Any help would be much appreciated Many Thanks Leah 0 Quote Link to comment Share on other sites More sharing options...
0 PPH Posted May 11, 2007 Share Posted May 11, 2007 You will need to log in to the client area and you will find it under my licenses You'll be glad you tried it too 0 Quote Link to comment Share on other sites More sharing options...
0 marie2007 Posted May 11, 2007 Author Share Posted May 11, 2007 Hi, thank you for your reply As I am just testing it out before deciding if it's ideal for what I need, I just want to install it on to the back end of an exsisting domain for now, can I do this? I have cpanel, would I upload it under public_html. Thanks Again Leah 0 Quote Link to comment Share on other sites More sharing options...
0 DataHosts Posted May 11, 2007 Share Posted May 11, 2007 Yes you would upload in public_html. It is a bit scary to see you using CPanel wanting to resale hosting and not exactly sure of CPanel structure. You would upload in public_html where the directory is where you wish to run the script. Be sure to create the MySQL with permissions to allow connection. 0 Quote Link to comment Share on other sites More sharing options...
Question
marie2007
Hi All
Many Thanks
Leah
3 answers to this question
