Terminate More then 1 of same product
Hi all
I offer a 31 day free trial of my product. This is managed with the free trial add-on and works very well. The big problem is people can order more then 1 trial per account.
I could never get an action hook to stop the person from fully ordering SO I have restored to using a `clean up` script to help.
This will terminate all related products if the user has more then 1
So if usera buys 2 trials - both will be terminated.
I use mysql to calculate if its duplicated - I know this can be optimized more - I really didnt care.
I hope someone else will find it useful.
<?php
// include WHMCS and base functions
require("../../dbconnect.php");
require("../../includes/functions.php");
require("functions.php");
$url = "http://..../includes/api.php"; # URL to WHMCS API file
$username = ""; # Admin username goes here
$password = ""; # Admin password goes here
$packageid="";
$allq = "SELECT O.userid FROM tblorders O, tblhosting TH WHERE TH.packageid='$packageid' AND TH.orderid=O.id";
$sq_allq = mysql_query($allq) or die(mysql_error());
$okarray=array();
while($row = mysql_fetch_array($sq_allq)){
if($row['userid']){
	$allqq = "SELECT TH.id, O.userid FROM tblorders O, tblhosting TH WHERE TH.packageid='$packageid' AND TH.orderid=O.id AND O.userid='".$row['userid']."'";
		$sq_allq2 = mysql_query($allqq)or die(mysql_error());
		$cnt=mysql_num_rows($sq_allq2);
		if($cnt > 1){
		while($row2 = mysql_fetch_array($sq_allq2)){
			echo "duplicate found ".$cnt." user #". $row2['userid'].", hosting id#".$row2['id']."\n";
			$postfields=array()
			$postfields["username"] = $username;
			$postfields["password"] = md5($password);
			$postfields["action"] = "moduleterminate";
			$postfields["accountid"] = $row2['id'];
			$postdata = http_build_query($postfields);
			$opts = array('http' =>
				array(
					'method'  => 'POST',
					'header'  => 'Content-type: application/x-www-form-urlencoded',
					'content' => $postdata
			$context  = stream_context_create($opts);
			$data = file_get_contents($url, false, $context);
			$data = explode(";",$data);
			foreach ($data AS $temp) {
			  $temp = explode("=",$temp);
			  $results[$temp[0]] = $temp[1];
			if ($results["result"]=="success") {
			  echo "ok\n";
			} else {
			  # An error occured
			  echo "The following error occured: ".$results["message"]."\n";
I run this as:
modules/freetrial/duplicates.php
Awesome job.
Just so you know on most hosts "file_get_contents" will not allow you to get the contents of a URL for security reasons. I suggest you use cURL to make your API requests to the terminate function :)
As well take a look at this quick tip I posted: http://forum.whmcs.com/showthread.php?t=36321
If you run the code on your local server you can save yourself the trouble of connecting to the server (why make a connection when you don't need to?). As well as removing the need for a username/password in the script.
