Help with joomla and whmcs
serhash
Hello I have a joomla 1.6
When i try to use the "Integration Code" or use the widgets, don´t works.
If you type a domain name and go search, don´t happened nothing.
I insert this code:
<form action="http://www.barnahosting.es/clientes/domainchecker.php" method="post">
<input type="hidden" name="token" value="7669842efb01a1a3e122433283ab33dc3ea2372e" />
<input type="hidden" name="direct" value="true" />
Domain: <input type="text" name="domain" size="20" /> <select name="ext">
<option>.com</option>
<option>.net</option>
<option>.info</option>
<option>.org</option>
<option>.es</option>
</select>
<input type="submit" value="Go" />
</form>
But when i save the article or the module, the action to my domain disappears.
And this is the html results.
<form method="post"> <input name="token" type="hidden" value="7669842efb01a1a3e122433283ab33dc3ea2372e" /> <input name="direct" type="hidden" value="true" /> Domain: <input name="domain" size="20" type="text" /> <select name="ext"> <option>.com</option> <option>.net</option> <option>.info</option> <option>.org</option> <option>.es</option> </select> <input type="submit" value="Go" /> </form>
I try with tiny, jck, but dont works
Can you help me please!
  • 2 months later...
I insert this code:
</select>
</form>
I'm having the same problem with widgets and integration links... Did you find a way to make it work? Can you please share the solution if any?:(
@Serhas,
The easiest way of doing this is going to your module manager and create a custom HTML module with your form code, make sure you give it a prober position_name and module name also disable the title.
Then in your template\index.php file add the following line <jdoc:include type="modules" name="position_name" style="xhtml" /> where you would like your form to appear.
Hope this helps
<<signatures to be set up in your profile>>
@computers.wheneva
Thanks for your input.
I'm having the same problem, but when I tried your solution and its still the same.
I tried with Tiny, JCE editor but no joy
Any other suggestions would be much appreciated.
Thanks and regards
@barnetpcservices & @Sherhas
If the custom HTML Module does not work, you can try the following
Follow these steps exactly :
1. Goto your templates directory
2. Create a directory includes or inc (Up to You)
3. Create a empty .html or .php file (In this case we call it filename.html)
4. Edit the above filename in this case filename.html and the content below
5. Save filename.html
Contents of filename.html
</select>
</form>
Now in your template index.php file add the following php code where you would like to have the lookup appear
<?php include("includes/filename.html"); ?>
That is it, you should now be able to see the domain lookup.
Computers Wheneva
http://www.wheneva.co.za
MonsterPay Gateway (Beta)
Sample.zip
Edited by computers.wheneva
Added Samples
</select>
</form>
Computers Wheneva
That works like a charm... Now I have to do the same for other widgets as well... Thank you very much...:D
