pipe problem yet again
5wayshost
i think the hardest thing about setting communications is making it automatic. I cant get support ticket or new order notification to the email setup in the admin area. *the email is a hotmail account different to other. Can someone suggest to me what could be going wrong here.
Hi 5wayshost,
Do you have another email address you can test with?
Sometimes Hotmail will ban an IP if they think you are spamming them. We have seen this happen before with no logical reason. The most common reason they will black list your IP is if a feedback form of a clients web site on the same IP is compromised by a spammer.
If you can setup another email address, other than Hotmail, it will save you a great deal of hassles in the long run, as you wont need to worry about not getting emails because of Hotmail at some random future date.
Cheers,
Paul
We have found that when having trouble with hotmail, you can send an email from your hotmail account to the email address you want to receive emails from then they seem to come through after that :)
Also you may want to install cpanel proxy to access your cpanel when the ports are blocked for access.
