danfelbm Posted December 7, 2010 Share Posted December 7, 2010 Hello, When I try to access the administrator panel, just it doesn´t work, I put the correct values but Im not redirected, I already tried in some other PCs, this is also happening to every client accessing the client area, it doesnt return an error message, just nothing happens. I already tried re-uplading files, everything, but nothing works, what can I do? Regards. 0 Quote Link to comment Share on other sites More sharing options...
Roger Posted December 7, 2010 Share Posted December 7, 2010 Edit your configuration.php file. Add the following line to it: $display_errors = true; Then try to access your admin portal. Report back any errors displayed. With more info maybe someone can help you. -Roger 0 Quote Link to comment Share on other sites More sharing options...
