wsd Posted October 15, 2010 Share Posted October 15, 2010 This is certainly not optimal, but it's a small step http://forum.whmcs.com/showthread.php?t=9944 In the file /templates/orderforms/default/adddomain.tpl Search for this www. <input type="text" name="sld" size="40" value="{$sld}" /> <select name="tld"> Replace it with <!—you name BOF: //--> {include_php file='/usr/home/domains/public_html/whmcs/idn.php'} <!—you name EOF: //--> www. <input type="text" name="sld" size="40" value="{$sld}" /> <select name="tld"> In the file /templates/orderforms/default/configureproductdomain.tpl Search for this www. <input type="text" name="sld[0]" size="40" value="{$sld}" /> <select name="tld[0]"> Replace it with <!—you name BOF: //--> {include_php file='/usr/home/domains/public_html/whmcs/idn.php'} <!—you name EOF: //--> www. <input type="text" name="sld[0]" size="40" value="{$sld}" /> <select name="tld[0]"> And Search for this www. <input type="text" name="sld[1]" size="40" value="{$sld}" /> <select name="tld[1]"> Replace it with <!—you name BOF: //--> {include_php file='/usr/home/domains/public_html/whmcs/idn.php'} <!—you name EOF: //--> www. <input type="text" name="sld[1]" size="40" value="{$sld}" /> <select name="tld[1]"> In the file /templates/default/domainchecker.tpl Search for this </form> {/if} <p>{$LANG.domainintrotext}</p> <form method="post" action="domainchecker.php"> Replace it with </form> {/if} <!—you name BOF: //--> {include_php file='/usr/home/domains/public_html/whmcs/idn.php'} <!—you name EOF: //--> <p>{$LANG.domainintrotext}</p> <form method="post" action="domainchecker.php"> /usr/home/domains/public_html/whmcs/idn.php <?php $encoded = ''; $decoded = ''; $add = ''; require_once('idna_convert.class.php'); $IDN = new idna_convert(); if (isset($_REQUEST['encode'])) { $decoded = isset($_REQUEST['decoded']) ? stripslashes($_REQUEST['decoded']) : ''; $encoded = $IDN->encode($decoded); } ?> <table width="85%" align="center" border="0" cellpadding="0" cellspacing="0"> <tr> <td width="40%" align="left">Domæne navn med æøå</td> <td width="10%"> </td> <td width="40%" align="right">Det er sÃ¥ det her du skal søge efter</td> </tr> <tr> <td width="40%" align="left"> <form action="<?php echo $_SERVER['PHP_SELF']; ?>" method="post"> <input type="text" name="decoded" value="<?php echo htmlentities($decoded, null, 'UTF-8'); ?>" size="20" maxlength="255" /></td> <td width="10%" align="center"> <input type="submit" name="encode" value="Encode" /><?php echo $add; ?></td> <td width="40%" align="right"> <input type="text" name="encoded" value="<?php echo htmlentities($encoded, null, 'UTF-8'); ?>" size="20" maxlength="255" /></td> </form> </tr> </table> Download idna_convert.class.php from http://phlymail.com/download/Goodies/idna_convert_064.zip Regards, 0 Quote Link to comment Share on other sites More sharing options...
