Need Help
JBruno
I have 3 servers configured in WHMCS.
In the first server, when I sell an account on the day after it appears on the client
Disk Usage: 3 MB, Disk Limit: 500 MB, 1% Used: BW Usage: 0 MB, BW Limit: 999 999 MB, 0% Used
(Last Updated: 15/09/2010 20:00)
In the other two servers nothing appears in the accounts of customers.
Someone can help me on this?
Thank you very much
Regards
JBruno :roll:
The only cronjob should be the one for WHMCS, which is executed on the server/account that contains the WHMCS installation.
What I was referring to is under Settings -> Automation Settings.. all the way at the bottom, there is a checkbox to update the usage statistics.
yes i have seen in
Miscellaneous
Tick this cancellation Requests box to Automatically terminate accounts with cancellation requests When Due.
Usage Statistics Update Tick this box to Update Automatically When the cron runs
and only appears to me the statistics of 1 server
