Problem with Ajax order form and Client_menu add-on
staher
I just upgraded to the new WHMCS version, and tried to test the new Ajax order form. When using the links provided for any product I get a blank page. I enabled error display in config.php and I got the following message:
Fatal error: require() [function.require]: Failed opening required './modules/admin/client_menu/init.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/xxxx/xxxxx/templates_c/%%F2^F28^F28B0D98%%header_inc.tpl.php on line 5
I am not a technical person, and have no idea what this means.
I tried to disable the client_menu add-on but the error remained the same.
I would appreciate any help here.
Thanks
