ozzie Posted April 2, 2007 Share Posted April 2, 2007 Matt, After the tax calculation problem, I now have found another problem: config = tax exclusive --------------------------------- Sub Total: $11.95 AUD Credit: $0.00 AUD 10.00% Tax Due: $1.20 AUD Total: $13.14 AUD Tax is fine, but the total should be 13.15 whether it is simply added up or calculated as 1.10 * 11.95 = 13.145 = 13.15 rounded. Cheers Willem version 3.1.1 0 Quote Link to comment Share on other sites More sharing options...
nzinside Posted April 2, 2007 Share Posted April 2, 2007 Hey Ozzie We had the same problem. It's not the tax issue. Just open up a ticket, then the gracious Matt will be able to sort it out for you. By the way, is your Planetdomain Registar working with no problem? My testmode doesn't seem to be working properly; an error message comes up (Error Code: 401 - Authorisation failure). Do you know any good place to find out more info on the WHMCS Planetdomain API module? I want to know what happens on my Planetdomain Account when a domain is registered in the test mode thru WHMCS. Is there any where I can see the domain register at the reseller's account? I have no clue on this. 0 Quote Link to comment Share on other sites More sharing options...
ozzie Posted April 2, 2007 Author Share Posted April 2, 2007 Hey Ozzie By the way, is your Planetdomain Registar working with no problem? My testmode doesn't seem to be working properly; an error message comes up (Error Code: 401 - Authorisation failure). Do you know any good place to find out more info on the WHMCS Planetdomain API module? I want to know what happens on my Planetdomain Account when a domain is registered in the test mode thru WHMCS. Is there any where I can see the domain register at the reseller's account? I have no clue on this. Hey nzinside, I haven't tested the PD module yet. Their test server is relatively new and I'm not sure how it works. You probably need to have the API enabled with Planetdomain first. Just open a ticket for Graheme Newberry and he will sort you out. You could always try the live server and delete any domains within three days to get a credit... I'm still unsure how it will handle the requirement to pass on a Australian Company Number (ACN) or Australian Business Number (ABN). This is mandatory input in the Planet Domain manual interface and I believe a auDA requirement. Ideas anyone ?? Cheers, Ozzie 0 Quote Link to comment Share on other sites More sharing options...
nzinside Posted April 2, 2007 Share Posted April 2, 2007 Hey Ozzie Graheme is sorting this out. Cheers mate! Shawn 0 Quote Link to comment Share on other sites More sharing options...
ozzie Posted April 2, 2007 Author Share Posted April 2, 2007 Do you know any good place to find out more info on the WHMCS Planetdomain API module? Hey Shawn, This document might help http://www.planetdomain.com/media/downloads/PlanetDomain_API.pdf Cheers, Ozzie 0 Quote Link to comment Share on other sites More sharing options...
nzinside Posted April 2, 2007 Share Posted April 2, 2007 You are the man! 0 Quote Link to comment Share on other sites More sharing options...
