[Solved] Enom does not work with v3.1
It could be a problem with enom.php file :(
Warning: fsockopen() [function.fsockopen]: unable to connect to resellertest.enom.com:80 in /home/username/public_html/whmcs_directory/modules/registrars/enom/enom.php on line 0
Could not connect to Server - Please try again later
Check that Test Mode isn't enabled in Configuration > Domain Registrars and that you don't have a firewall blocking the outgoing connection. Everything seems to be working ok here with it.
Matt
Matt
My test mode is not enabled nor have I had problems with my firewall before, but I disabled it anyways to see if it would work but it's a no go!
