customized domain register with invoicepaid hook problem
emrag
i'm trying to add my own customized domain register api. i want when an invoice paid, register ordered domain automatically. i'm using invoicepaid hook. but problem is i cant get details of order with invoice id. for example this code doesnt return anything. i look db and i see when an order comes in tblorders table invoiceid column is "0". whmcs update invoiceid column after hook files run so i cant get order details with invoice id. what can i do or i'm using wrong hook point?
(note: i added credits to an user and i try this api with him. so if credit balance is enough it must be automatically register.)
function hook_invoicepaid($vars)
$invoiceid = $vars['invoiceid'];
$sql = "SELECT * FROM tblorders WHERE invoiceid = '$invoiceid' LIMIT 1";
$result = mysql_query($sql);
$row = mysql_fetch_object($result);
print_r($row);
add_hook("InvoicePaid",1,"hook_invoicepaid");
Am I missing something, don't you just set that in Settings -> Domain Pricing under Auto Registration? or is your hook wanting to do something else as well.
i know there is but i need to run some custom functions while registering domains.
