adding hook problem
emrag
i'm trying to add hook. i'm using resellerclub api. it works fine if my hook file look like that:
	$SERVICE_USERNAME = 'username';
$SERVICE_PASSWORD = 'password';
$SERVICE_ROLE = 'reseller';
$SERVICE_LANGPREF = 'en';
$SERVICE_PARENTID = '1';
$LIB_DIR ="pathhere"; // Absolute or relative Path to your Lib folder
// resellerclub api
include($LIB_DIR."apiutil.php");
include($LIB_DIR."DomOrder.class.php");
include($LIB_DIR."response.class.php");
$serviceObj = new DomOrder($LIB_DIR . "wsdl/DomOrder.wsdl");
$domainName = 'example.com';
$option = array('All');
$domdata = $serviceObj->getDetailsByDomain($SERVICE_USERNAME, $SERVICE_PASSWORD, $SERVICE_ROLE, $SERVICE_LANGPREF, $SERVICE_PARENTID, $domainName, $option);
print_r($domdata);
but if i create a function and add these codes to in it there's no output. that doesn't work:
function test_domain()
// resellerclub api
print_r($domdata);
test_domain();
ps: i know how to use hooks. like add_hook("InvoicePaid",1,"test_domain"); ...ect.
please give us the hole context of your "hook add task".
hint: the hook ClientAreaPage is always called except of cron. so you can try first on this.
are the path correct? give some debug output on method "getDetailsByDomain". does it work?
