makkie Posted May 4, 2006 Share Posted May 4, 2006 Hi all. I just install v.2.4 and start change language file. Our customers are using 2 bytes character like Korean, Chinese and Japanese. I coundn't find where to modify charset especialy Email function. I hope Matt add charset field to each lang file that effect to admin area and email function. Let me knwo if anybody has solution of this. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
yawsh Posted June 6, 2006 Share Posted June 6, 2006 I think adding a direction set also important for some language like mine - Arabic Regards Mohamed 0 Quote Link to comment Share on other sites More sharing options...
basic5hosting Posted October 2, 2006 Share Posted October 2, 2006 Has this problem been addressed? I am launching a new service to the Chinese marketplace. Please advise?? 0 Quote Link to comment Share on other sites More sharing options...
johhnyb Posted December 28, 2006 Share Posted December 28, 2006 I have got the same problm with polish charset integration with emails! Any clue? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted December 28, 2006 WHMCS CEO Share Posted December 28, 2006 Configuration > General Config > Mail > Charset (this affects client area and emails - not the admin area yet however) Matt 0 Quote Link to comment Share on other sites More sharing options...
megaweb Posted February 18, 2008 Share Posted February 18, 2008 Hi, Matt, Your chinese character is traditional chinese. It is no use for the people in China. Could you please tell me how to change it into simple chinese ? I tried to make the character in clients/whmcs/lang/Chinese.txt to simple chinese. But it doesnot work. Thanks in advance! 0 Quote Link to comment Share on other sites More sharing options...
megaweb Posted February 24, 2008 Share Posted February 24, 2008 Could some body tell me how to translate the traditional chinese to simple chinese? It is really no use if you use tradition chinese charset in China. 0 Quote Link to comment Share on other sites More sharing options...
ttju Posted March 4, 2008 Share Posted March 4, 2008 Configuration>General>Localization You need to set the charset to UTF-8. You will be able to see the characters on the webpage but they are still in Traditional Chinese Fonts. The only way to do this properly is to replace all the traditional fonts into simplified fonts one by one. If your readers can understand Traditional Chinese changing the charset to UTF-8 might be the easiest. 0 Quote Link to comment Share on other sites More sharing options...
