Maxime Posted April 27, 2010 Share Posted April 27, 2010 I am a junior programmer and I can't add a order and I don't understand where is my error(s) this is my script (just the add order part). I can actually add a client. Help me! $orderpostfields["username"] = $username; $orderpostfields["password"] = md5($password); $orderpostfields["action"] = "addorder"; $orderpostfields["clientid"] = $results["clientid"]; #1 $orderpostfields["pid"] = $_POST['choiceRB']; #1 $orderpostfields["domain"] = $_POST['txtDomain']; # http://www.test.com $orderpostfields["billingcycle"] = "monthly"; $orderpostfields["domaintype"] = $domainType; # transfer or register $orderpostfields["regperiod"] = "1"; $orderpostfields["paymentmethod"] = "paypal"; $ch = curl_init(); curl_setopt($ch, CURLOPT_URL, $url); curl_setopt($ch, CURLOPT_POST, 1); curl_setopt($ch, CURLOPT_TIMEOUT, 100); curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1); curl_setopt($ch, CURLOPT_POSTFIELDS, $orderpostfields); $data = curl_exec($ch); curl_close($ch); foreach ($data AS $temp) { $temp = explode("=",$temp); $resultsOrder[$temp[0]] = $temp[1]; } if ($resultsOrder["result"]=="success") { #If success return th orderID and invoiceID print("OrderID".$resultsOrder["orderid"]." InvoiceID".$resultsOrder["invoiceid"]); } else { # An error occured echo "The following error occured: ".$resultsOrder["message"]; } } 0 Quote Link to comment Share on other sites More sharing options...
m00 Posted April 28, 2010 Share Posted April 28, 2010 Put print_r($resultsOrder); below the following and post the output: foreach ($data AS $temp) { $temp = explode("=",$temp); $resultsOrder[$temp[0]] = $temp[1]; } 0 Quote Link to comment Share on other sites More sharing options...
