synnyzter Posted April 27, 2010 Share Posted April 27, 2010 (edited) I have a pretty big problem with the checkout process on my WHMCS. I have all my packages setup free for now for testing purposes as usual.... The problem is whenever you try to purchase a hosting plan, if you choose either "register new domain" or transfer domain" and click the proceed button, all it does is refresh the page. it gives no errors, just refreshes over and over. Now if I try a plan without a domain, just hosting, it works fine. So, obviously it's an issue with the domain process. I have tried it "live" and in "sandbox" mode, tried different templates, everything short of a new install which I cannot do according my web hosts rules. Any idea why it gets stuck on "step 2" domain options? I do have an account with namecheap.com, API enabled, API key entered into WHMCS, cpanel IP entered in white list on namecheap.com... About all the details I can think of that are relevant. Thanks in advance all! btw: url is atishost.net in case anyone needs to see it...and yes it is templated... Edited April 27, 2010 by synnyzter 0 Quote Link to comment Share on other sites More sharing options...
synnyzter Posted April 27, 2010 Author Share Posted April 27, 2010 Found the problem, when I added the TDL's I used caps, duh... 0 Quote Link to comment Share on other sites More sharing options...
