PaulZ Posted March 2, 2010 Share Posted March 2, 2010 I’ve searched through the forum but cannot figure the answer to my requirements. I want my clients to have an extra option in WHMCS at: Portal Home » Customer Area » My Domains » specfic-domains.co.uk At the moment the Domain Management options for an Enom registered domain are : Renew Domain | Contact Info | Email Forwarding | DNS Management | Register NS OK – so …. DNS Management is a fine option for the Advanced User (on template clienetareadomaindns.tpl ) This allows them to set URL Forwarding, Cloaked Forwarding A, MX, MXE, CNAME & SPF records What I really need is a separate screen aimed at the non-advanced user with a cut down list of options which just allows the User to set : URL Forwarding, Cloaked Forwarding I’d call this screen Web Forwarding. How can I create this? Do I just duplicate the clienetareadomaindns.tpl template rename it and strip out the options I don’t need? If so how would I call this template from clientareadomaindetails.tpl? Thanks Paul 0 Quote Link to comment Share on other sites More sharing options...
