brandom9 Posted February 8, 2010 Share Posted February 8, 2010 Earlier, I hosted WHMCS in Directadmin without any problem. After transfering to cPanel, it's not working correctly anymore. I have not received the 'WHMCS Cron Job Activity' report anymore. I checked in log activity and found the last activity is 'Cron Job: Running Usage Stats Update', but no email report sent to me. Anyone can help me on this ? Thanks in advance. 0 Quote Link to comment Share on other sites More sharing options...
BullsoftHosting - Tom Posted February 8, 2010 Share Posted February 8, 2010 Have you setup the cron jobs in cPanel yet? 0 Quote Link to comment Share on other sites More sharing options...
brandom9 Posted February 10, 2010 Author Share Posted February 10, 2010 Yes. of course i setup the cron. I tried to modify php.ini like below, but still no luck. max_execution_time 400 memory_limit 64M Thanks 0 Quote Link to comment Share on other sites More sharing options...
scurrell Posted February 10, 2010 Share Posted February 10, 2010 Yes. of course i setup the cron. I tried to modify php.ini like below, but still no luck. max_execution_time 400 memory_limit 64M Thanks We found 64M way too low. Try 128 or even 256 0 Quote Link to comment Share on other sites More sharing options...
brandom9 Posted February 10, 2010 Author Share Posted February 10, 2010 Increasing to a higher memory_limit will also not be working. The only way to fix this is; by disabling the 'Update Usage Statistics' in 'Automation Settings' section. 0 Quote Link to comment Share on other sites More sharing options...
scurrell Posted February 10, 2010 Share Posted February 10, 2010 Increasing to a higher memory_limit will also not be working. It was worth a try. Certainly worked for us. 0 Quote Link to comment Share on other sites More sharing options...
