Problem in creating template for WHMCS
alzawyah
Hi, Actually this is my first template for WHMCS and it's in Arabic (RTL) you can change the language back to English.
http://www.alzawyah.com/order
I have attached my Header,homepage and Footer.tpl files plus the CSS.
my problem is in the first page I get the copyright info (WHMCS Copyright) on top of the page .
I need to set it on bottom...:!::?:
and the next problem is when you click on any link (such as ticket or client area) the righ bar goes on bottom of the site and expands..
could any one please help me with this ... I am really confused ... the template is working fine on jomla as you can see it working (http://www.alzawyah.com)
but when I tried to set the template on WHMCS I come up with mentioned problem...
Style.zip
You may have broken your layout while converting it to a WHMCS template.
Try adding or taking away a </div> at the top of the footer.tpl.
You can style the "powered by" text, but it takes a while.
You just need to add a div at the bottom of each file in the template folder, then close it off in the footer... Cart.php and a few other pages need to be detected by a little php or they will break your layout.
