Adonis Posted January 10, 2010 Share Posted January 10, 2010 Hello it seems that our server was compromised and someone has injected some code into our site. We didn't found the code so we need to make a fresh install with clean files. Can someone tell us how we can do this? step by step? Thank you very much Cheers 0 Quote Link to comment Share on other sites More sharing options...
aXeR Posted January 10, 2010 Share Posted January 10, 2010 Don't you have any backups you can use? Was your installation up-to-date? 0 Quote Link to comment Share on other sites More sharing options...
Adonis Posted January 10, 2010 Author Share Posted January 10, 2010 Don't you have any backups you can use? Was your installation up-to-date? Hello aXeR The infected installation is UP to date. No back-ups uninfected... Cheers 0 Quote Link to comment Share on other sites More sharing options...
Adonis Posted January 10, 2010 Author Share Posted January 10, 2010 Problem solved Just keep only configuration.php from old instalation and add new files. Then setup correct CHMD and voila.. Thanks WHMCS Support! 0 Quote Link to comment Share on other sites More sharing options...
