WHMCS 4.1.2. and OnlineNIC, does it work or not?
Leonidas_g
Almost two weeks now I'm opening tickets to my isp support, onlineNIC support,
in order to find out if WHMCS onlineNIC module actually works.
Registering a domain I get errors:
Domain Registration:
"An Error Occured
6000 - Checksum error: Checksum error - checksum"
or
"An Error Occured
2400 - Command fail: Command failed - 2"
The answers I get from onlineNIC are "The error "Checksum error" indicates that the Chksum command you input is incorrect" &
"we suppose you need to make sure the performance for WHMCS workable with WHMCS provider company, thank you for your cooperation."
Also there is a problem with registering .eu Domains with onlineNIC - We just can't have them registered with any automated system, and we have to register them manually!
.org Domain transfer:
"An Error Occured
1001 - 1001: Command completed successfully; action pending - no value"
(this seems to work, but the transfer gets cancelled after a few hours)
Anyone had these problems? Other registrars eg. ENOM work normally with WHMCS and .eu domains? I can't pay for an automated system and register the domains manually!
  • 1 month later...
I have the exact same problem. First time it gave me an error with code "6000- checksum"
Now, it is giving ---
An Error Occured
1001 - No response from OnlineNIC: Command completed successfully; action pending - no value
I have 20001 port opened in firewall and Test Mode is off at registrar settings. Can anyone from WHMCS help please?
Thanks,
Vijay
