seether Posted December 28, 2009 Share Posted December 28, 2009 i have 4 different sites on different domains and i wont to used whmcs on them all since upgrading from whmcs 3 to version 4 i cant use whmcs on an the other domains im using iframes at the moment but its not the best solution 0 Quote Link to comment Share on other sites More sharing options...
GORF Posted December 29, 2009 Share Posted December 29, 2009 Short answer = NO. Long answer = NO, read and understand how it works and is licensed. 0 Quote Link to comment Share on other sites More sharing options...
megatr0n Posted December 29, 2009 Share Posted December 29, 2009 It's not possible to run whmcs client side but what you can do try is running it on a locally installed webserver emulator(not really a emulator but you get the gist) like WAMP or XAMPP. You would also have to make sure you have the required softwares already installed including ioncube. This probably won't work with the latest whmcs versions but it might work with the older ones. 0 Quote Link to comment Share on other sites More sharing options...
