Multi Currency Problem
blueprawn
Hi All
Ok I have set up my WHMCS with 2 currencies Euro and GBP
Euro is currency 1 and GBP is currency 2
When I set up product and add either &currency=1 or &currency=2 after the product link prices are always displayed in GBP which is my default currency
It was working but its not now - does anyone have a solution?
Thanks
Edited by blueprawn
I am not sure if I completely understand you. But I will try to help.
For me, what I usually do is that I put in the Default Currency Values first.
Then I go to General Settings > Currencies
and then I click "Update Product Prices." After you do this, then your Default and Secondary Currency should be different.
I hope this was able to help somehow.
