HELP! - 2 problems!
lewis4490
I have got 2 problems so far.
Here they are:
When i go to allow clients to register it will click the box and then when i press save it says it has saved it but when i go to check to see if i can register as a client it does not allow this - Says "not allowed"
And my 2nd problem:
I'm getting this error:
You do not have the required permission to perform the selected operation!
Action: Configure Ban Control
When i try to do anything!
Please help me :)
Thanks in advance
Lewis
for No. 1:
try clearing your Cache and the folder: templates_c (REMOVE ALL BUT INDEX.PHP)
I would try that but without whmcs allowing me to do so without this damn page showing up every time i try.
But i did remove all but index.php from that folder you told me to.
Lewis
I see you logged in with a different user before Have you now removed that user or can you try that one?
it look like you hit Uncheck All then saved it. so I think you can only now do 1 of 2:
1, remove the script and re install it,
2, remove the database and install the backup you have,
Ok first try this:
from phpMyAdmin
Drop tbladminperms (yes drop)
then run this:
-- Table structure for table `tbladminperms`
CREATE TABLE IF NOT EXISTS `tbladminperms` (
`roleid` int(1) NOT NULL,
`permid` int(1) NOT NULL,
KEY `roleid_permid` (`roleid`,`permid`)
) ENGINE=MyISAM DEFAULT CHARSET=latin1;
-- Dumping data for table `tbladminperms`
INSERT INTO `tbladminperms` (`roleid`, `permid`) VALUES
(1, 1),
(1, 2),
(1, 3),
(1, 4),
(1, 5),
(1, 6),
(1, 7),
(1, 8),
(1, 9),
(1, 10),
(1, 11),
(1, 12),
(1, 13),
(1, 14),
(1, 15),
(1, 16),
(1, 17),
(1, 18),
(1, 19),
(1, 20),
(1, 21),
(1, 22),
(1, 23),
(1, 24),
(1, 25),
(1, 26),
(1, 27),
(1, 28),
(1, 29),
(1, 30),
(1, 31),
(1, 32),
(1, 33),
(1, 34),
(1, 35),
(1, 36),
(1, 37),
(1, 38),
(1, 39),
(1, 40),
(1, 41),
(1, 42),
(1, 43),
(1, 44),
(1, 45),
(1, 46),
(1, 47),
(1, 48),
(1, 49),
(1, 50),
(1, 51),
(1, 52),
(1, 53),
(1, 54),
(1, 55),
(1, 56),
(1, 57),
(1, 58),
(1, 59),
(1, 60),
(1, 61),
(1, 62),
(1, 63),
(1, 64),
(1, 65),
(1, 66),
(1, 67),
(1, 68),
(1, 69),
(1, 70),
(1, 71),
(1, 72),
(1, 73),
(1, 74),
(1, 75),
(1, 76),
(1, 77),
(1, 78),
(1, 79),
(1, 80),
(1, 81),
(1, 82),
(1, 83),
(1, 84),
(1, 85),
(1, 86),
(1, 87),
(1, 88),
(1, 89),
(1, 90),
(1, 91),
(1, 92),
(1, 93),
(1, 94),
(1, 95);
Then try logging in?
